I'm going to buy a Magnehelic® Differential Pressure Gage. what range is most usefu
Im gonna measure pressure differentials in the intake and also measure pressure on various points on the exterior (at different speeds).
Any idea what range I should get?<ul><li><a href="http://www.dwyer-inst.com/htdocs/pressure/Series2000Price.cfm#CRA">Dwyer</a></li></ul>
0-10. The one I have is 0-25 and not as sensitive at low levels as I'd like..
BTW, I mounted in a standard electrical outdoor box as seen here:
<img src="http://images2.fotki.com/v11/photos/7/7305/166599/DSCF0165-vi.jpg">
because im a NOOB
however, this gauge can measure the difference in pressure bettween two points in the intake system
so then you can see that say, air pressure before the MAF for example, is A. And after the Maf it mnight be B. And then you would know wether the Maf or any given component in the system is reducing air flow.
You can also use it to see if air pressure is higher (edit) than ambient air pressure say if you wanted to find areas of high or low pressre on the front end of your car at various speeds
Mark.core
NY / NJ / CT Discussion
01-19-2006 12:13 PM
scott12v@pghaudi
12v V6 Discussion
17
02-04-2004 06:22 AM
2001, buy, car, cat, differential, explained, gage, gauge, magnahelic, magnehelic, magnhelicb6, pressure, wiki, works
