I'm hearing a weird sound coming from what it sounds like is my spring.
A little more info would help.
Can you push the rear of the car down and create the squeak?
Does the squeak only occur at slow speeds over speed bumps?
Only from one side or the other?
Most common sqeaks can include anything from the sway bar to the bad shock or springs.
Here's a picture of the driver's side.Arrow indicates the joint>>>
<center><img src="http://pictureposter.audiworld.com/43168/squeeky_bushings.1.jpg"></center><p>squeeking. I spray silicon lubricant on it every couple months. Remember to do both sides of the car. See how it looks wet? I coated it until it got into the tight spots.
If it's the sway bar, the dealer should replace for free >>>
there is an updated version of the sway bar that doesn't have the plastic inserts. the inserts crack over time. I got mine replaced by the dealer for free.
GDawgA4
08-24-2006 03:43 AM
GrandPaJohn
9
07-12-2005 01:23 PM
TT_C_YA
08-06-2002 06:13 AM
djnelsen
08-14-2001 04:52 PM
