INPUT NEEDED GARRETT TURBO KIT
Has anyone here used this?!?!?! IF so what are your thoughts?<ul><li><a href="http://www.turbobygarrett.com/turbobygarrett/kits/kit_VW_18T_Transverse.htm#">Garrett Turbo Kit FROM GARRETT</a></li></ul>
Software I would guess will be coming pretty soon, Although you can buy the hardware kit now(from ATP) I would wait for the software from the various companies.(that way you can go with whatever they use for the injectors and pump) and you'll be looking at alot more bang for the buck (300whp+) and great torque. Look at vortex, they have lots of posts lately about the GT28RS and even one guys somewhat custom car dyno.
Be sure to keep in mind the other things you probably will want to upgrade also though (fmic,clutch,hpa gear set?). So I would guess at least 3k minium and more depending on what other things you add on and wether you do it yourself or not.
btw, your caps lock key is on - you on AOL?
And at the moment they do have software that comes with their full blown high quality kit wich uses the a differnt turbo. If you want it today go ahead, nothing wrong with it and there are probably lots of other reasons but for my desires I wouldnt know as I wont be falling into that category.
The full monty for the gt28rs isnt out yet, Yes you can do it if you know and want to play with the fueling but as of the moment the APR,Revo big turbo, or GIAC software isnt out as far as I know to purchase yet. (Unless you were one of the lucky few guinea pigs)
here is some info<ul><li><a href="http://forums.vwvortex.com/zerothread?id=1218749">http://forums.vwvortex.com/zerothread?id=1218749</a</li></ul>
APR manofild where cylinders 1/4 don't mix with cylinders 2/3, complete proven kit with software, EMCS, 91, 93, 100, 104, valet programs, did I mention the manifold?
MiliTTary
9
08-17-2006 03:07 PM
