Installing an iPod integration kit this weekend. Any advice is appreciated.
I have not used the Dice kit (it helps if you read the entire post) but the...
hardest part of the install kit I used was removing the pins for the CD changer to install the ipod kit. You have to be a little forcefull in order to get them out. I assume that this kit works in the same way.
to remove the 'pins' (in this case, the DIN connector), you need to pinch the little clip
that locks it into place. then it slides out easily. and it goes back together quite easily as well...and clicks to lock them into place.
This kit has a vehicle specific interface cable so I don't have to worry about the pins.
And I'm installing it to the non-Bose unit in my 2002. Controls for a changer but no CD changer was installed. Thanks.
ayush
04-29-2003 01:53 PM
spk
02-14-2001 06:16 PM
spk
02-14-2001 06:14 PM
Stephen Kormilo
08-12-1999 02:36 PM
