Interesting observation wrt dying battery - "lazy" tachometer.
Old 11-25-2003, 06:10 PM
FasTTr's Avatar
Default Interesting observation wrt dying battery - "lazy" tachometer.
About 4 to 6 weeks ago I noticed my tachometer would stay at zero for about 2 to 5 seconds after the car started. I was worried that the cluster was failing. Then in cold weather during a trip to Penn., my clock reset while starting the car. Yesterday we had cold weather in Texas and my car was noticeably weak starting and the clock reset again. The battery had a dead or dying cell. After replacing the battery today, my tachometer is no longer "lazy". It begins working as soon as the engine starts.
So it appears that this delay in the tachometer working is a probably early indicator of a low voltage situation related to a battery on it's last legs. Thought this might help others diagnose a battery issue before it dies completely.
Old 11-25-2003, 06:36 PM
AudiWorld Uber User
TTschwing's Avatar
Default That's why I have this little $25 insurance policy...>
<center><img src="http://images2.fotki.com/v21/photos/7/7305/224186/DSCF0201-vi.jpg"></center><p>
It's a good diagnostic tool as are most gauges...<ul><li><a href="http://public.fotki.com/ttschwing/airfuel_and_voltmet/">A/F and matching volmeter for $45</a></li></ul>
Old 11-25-2003, 06:49 PM
Junior Member
GkRiKoRi's Avatar
Default You can also view the warnings on the Temperature Display
C21 is the Number of low voltage occurrences, non-transient<ul><li><a href="https://www.audiworld.com/tech/int6.shtml">https://www.audiworld.com/tech/int6.shtml</a</li></ul>
Old 11-25-2003, 06:57 PM
Member
Boosted's Avatar
yeah I have doubts as to how accurate that display is...
Old 11-25-2003, 07:03 PM
Junior Member
GkRiKoRi's Avatar
I use it to monitor my coolant temp and it has proper resolution
Old 11-25-2003, 07:12 PM
Member
Boosted's Avatar
Default I find that it is somewhat inaccurate...or maybe
the sampling rate is to slow...
Old 11-25-2003, 07:24 PM
JustJeff's Avatar
Default Mine was $16.99
<img src="http://jbipes.home.comcast.net/jpgs/voltmeter.jpg">
Oh, I took it apart, of course, to fit my Euro Lower dash<ul><li><a href="http://www.cetsolar.com/voltmeter.htm">12 voltmeter</a></li></ul>
Old 11-25-2003, 07:50 PM
gtt
gtt's Avatar
Default I find if I don't drive the car for a week or more it happens.....
But once I use the car regularly the tach comes on normally.
Old 11-25-2003, 10:28 PM
JohnLZ7W's Avatar
Very interesting, mine has been doing this for a few weeks, I was blaming the cold temps.
Old 11-26-2003, 04:20 AM
New Member
case's Avatar
Default It's good to know others have the same problem, my tach only acts up when the weather is cold too,
never crossed my mind that it could be the battery. TT is 3 1/2 years old with 46k, might need a new battery. I also get the temp warning for about 30 seconds on very cold mornings.
Ulilbastrd
S4 (B8 Platform) Discussion
06-06-2014 12:51 PM
T0M3K
18
03-31-2007 06:22 AM
Asicks2.7T
02-01-2006 06:05 AM
mx-5
15
11-17-2004 08:50 AM
CTMechE
01-14-2004 07:07 AM
Quick Reply: Interesting observation wrt dying battery - "lazy" tachometer.
