interior turn signal light staying on solid
I finally got around to putting my smoked side markers in, removing the side reflectors on the light housing, and painting it. Put it all together, worked fine for 1 day, looks great. But on my way home from work today the when i used my turn signals the light inside stayed solid. I played with it for a bit but it just stayed solid but sometimes blinked once or twice. I didnt check what the outside lights on the front and rear are doing(very very hot out, just got home from work.)
Anyone ever have this problem? I made sure all connections where secure on the lights.
Your reservoir was probably just about empty and the smoked markers put it over the edge. It's pretty easy to replace the blinker fluid reservoir yourself.
Get the imported stuff...:-)
<img src="http://images111.fotki.com/v730/photos/7/7305/52227/blinkerfluid-vi.jpg">
Seriously, the blinker relay is a common failure. It's part of the red hazard switch in the dash. How-to replace is in the FAQ..
Well, I've had a chance to relax and I probably should've researched a bit before posting right after work. I guess I deserve the blink fluid replies... ;]
I've seen to answers either hazard switch(easiest) or the turn signal stalk. Anyone have this exact issue and one didnt work? If not I guess its time to order the hazard switch.
sufficient current to make the blinker function. At least I've had that on other vehicles I've owned.
