I've decided to make a very modest stereo upgrade to the TT
and save the big system for a non-sports car. Thanks for letting me listen to your dope systems at TTE, but I think I'd rather put my TT mod money towards suspension right now after seeing that at TTE also ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
I'm thinking replacing the speakers in the door will be a good start and I like these. Just wanted to know before I get them if they will fit for shizzle?
Infinity Kappa 60.5cs
6-1/2" Component Speaker System (evan, is this what you got?)
<img src="http://www.ikesound.com/images/ebay/InfinityKappa60.5cs.jpg">
Features-
Ceramic Metal Matrix Diaphragm Plus One woofer cone
1" C.M.M.D. dome tweeter can be flush-, surface-, or angle-mounted
hi-roll rubber surround
2-way crossovers (high-pass/low-pass at 3500 Hz, 18 dB/octave)
frequency response 45-21,000 Hz
power range 2-90 watts RMS
peak power handling 270 watts
sensitivity 90 dB
top-mount depth 2-3/16"
So these should work, eh? For a hundo-fity I figure it's a damn fine deal
Also, will the crossovers fit in the door in the factory location?
Crossover Dimensions: L=4.251", W=3.008", H=1.437"
Thanks!!!
Features-
sensitivity 90 dB
Thanks!!!
And if I'm not mistaken, the Bose system amp operates at a 2 ohm load, requiring either 2 pair of 4 ohm speakers per side, or swap out the amp. I'm currently researching various sources to find 2 ohm speakers....no luck so far :-(.
Let us know if you find any! Good luck!
shooTTr
shooTTr
And, do you wanna fly out to cali June 8th for that road trip?
Lastly plan on going to that Eden, in fact that whole area both this and next Friday.
also, did you do the install on it? hard? I've got non-bose.
June 8th to cali...that might work...what are the details?
Eden...nice d00d...make SURE to say hi to megan for me....or at least drool over her
Those are the snazzier model that directly replaced the outgoing model I purchased (remember the Crutchfield deal I told you about?) These newer ones are a little more efficient (by 1dB). Crossovers look to be the same size as mine. They should work great!
BTW, the reason my crossovers were a pain is because I was trying to keep them under the foam inner panel liner to avoid moisture. I ended up mounting them with their plastic covers removed, inside of ziploc bags. :-) Don't worry, you'll find a place for them.
