I've got the drips.......
You may remember last weekend that I posted some pics of some areas of the bottom of the engine when I was doing my FMIC install.....some areas around the bottom driver's side of the engine were a little wet with oil. It appeared it was coming from somewhere above....Here's the wet areas:
<img src="http://images20.fotki.com/v355/photos/4/469393/4234841/100_1566-vi.jpg?1162679221">
<img src="http://images19.fotki.com/v358/photos/4/469393/4234841/100_1567-vi.jpg?1162679245">
<img src="http://images20.fotki.com/v355/photos/4/469393/4234841/100_1568-vi.jpg?1162679269">
<img src="http://images19.fotki.com/v358/photos/4/469393/4234841/100_1602-vi.jpg?1162679291">
<img src="http://images19.fotki.com/v358/photos/4/469393/4234841/100_1603-vi.jpg?1162679322">
So....I was poking around and noticed this little "tee" looking fitting. It appears oil-gummy-wet. In the first pic, it's in the area down between the fuel pressure regulator and the big silver round valve there.....
<img src="http://images20.fotki.com/v356/photos/4/469393/4234841/100_1604-vi.jpg?1163115320">
And here's two zoomed in shots of this tee....What is it and could this be what is leaking/dripping and dripping down onto the engine and into my belly pan?
<img src="http://images20.fotki.com/v355/photos/4/469393/4234841/100_1605-vi.jpg?1163115340">
<img src="http://images19.fotki.com/v354/photos/4/469393/4234841/100_1606-vi.jpg?1163115361">
I think that might be the source of my leak as well (my engine has the same drip pattern as yours). I'm also thinking I might have a leak from the seal where the driveshaft comes out of the transmission tho.
you can buy a new one, and it's probably worth it to change the valve itself too, it's the plastic type. The parts are "dealer items" and IIRC, I saw them on Impex the other day too. You'll have to cut off the single use clamps and replace them with the screw type...
GorTT
10
04-16-2008 06:18 PM
my S just crapped out. was low on fuel and engine started doing gentle -but strong/steady- power sur
quattro.pilot
Audi Original "S" Cars
09-30-2006 12:37 PM
tetraelement
05-31-2006 10:07 PM
TurboEnvy52
08-17-2003 07:56 PM
timmy alex
01-19-2003 05:57 PM
