I've searched before and asked before but can someone definitively tell me which battery...
brand and part number (if possible) they used for a replacement in a 2001 TT Roadster-not a coupe. Want a drop in replacement it at all possible. Why the hell does the box have to be different than the coupe-oh, because that would make things too easy.
PS: please don't beat me for asking this question-again.
I bought a drop in at O'Rielly yesterday for $55. Its about an inch shorter, but the same
front to back and side to side. the factory "mitten" fit perfectly.
Also, I didn't have to reprogram my Bose! I turned the key and it worked perfectly.
Sweet!
Sweet!
Re: Excellent-Batteries Plus, here I come. Thanks.
You might want to try Advance Auto... if theres a location in your area.
Also when you pick up your Optima, you'll see included two red plastic spacers which some cars require to mount the battery....
Didn't need them in my 2001 TTR.
Don't forget you will probably need to write down the radio codes, and may have to work the key and window issue when you disconnect the current battery.
Have fun!
Have fun!
