Jack Stand question: I see the rubber jack pads and use them to quickly jack up the car, but...
#11
If your reading this tonight...have a good night sleep and thank you so much for your help.
If your reading this tomorrow...I gots one more question for you...Again, I haven't looked under to car to verfiy these crazy braces but I don't like the line about the car could tip over! Is that with the factory jack only? I'm using a regular hydraulic floor jack, do I still need to be extra careful? Or, could I jack each side up at the previously discussed control arms locations and then jack stand at the donuts to avoid 'tipping' the car. I think I'm almost there...LOL
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
#12
Robby:
Since you would be placing the jack under the Haldex brace, which is in the center of the car, hte car would be balancing on a single point. If you were to put pressure on one rear corner of the car with a jack stand under it, the car could fall off the jack itself.
So long as you are careful, it will not be a problem. I have done exactly what you want to do, it is very easy. I know Emil has done the same thing as well.
Here is a pic of the car on the single jack . ..
<img src="http://albums.photopoint.com/j/View?u=1456758&a=12528288&p=47197017&Sequence=0&re s=high">
fkacct
11
12-23-2005 09:39 PM
OTOF
20
09-19-2002 06:48 PM
