Jason D. Bracketman... are these the subframe bolts?
These look like the big green suckers... got part numbers from my tech and ordered from dealer. Just want to make extra sure!
<IMG SRC="http://www.evan.com/tt_pics/milltek/stretchbolts.jpg">
The front subframe was shifted with the bolts loose but not removed then torqued to 78lbs + 1/4 turn(if I remember right)
then tightening them to 74 ft. lbs. plus 90 degrees, so yes, 1/4 turn.
Peter, I've spoken to three Audi techs and several folks here about these bolts. My trusted local performance shop explained that these bolts are a stretch bolt... called Torque-to-Yield, or something like that. At the base of the bolt is a non-threaded area narrower then the threaded part. This is the area that stretches when you torque the bolt, and I suspect is why the manual specifies an additional 90 degree turn. Once the bolt has been stretched once, it has done its job and should be replaced if it is ever removed. If you're really **** like me, then loosened = removed for sake of safety.
They cost $30.37 for the set in the picture... I'm going with factory specs and not taking chances.
....torque range is indeed a stretch bolt and should be replaced. This is of course in the ideal world and very often is not done. If given the opportunity and time, then try to replace them.
alki4000cs
10-29-2008 09:46 AM
BrianN
10-12-2003 09:38 PM
Luke@tirerack
20
01-18-2002 08:49 AM
Luke@tirerack
17
01-15-2002 04:01 AM
