John S, here's some flow reading this AM on my way to work...
226.42 g/s @ 6160 RPM, manifold pressure 2250, temp reading 39*C (amibient temp of 84*F)
My setup is as folows:
Dahlback customed tuned
Forge FMIC
Airetek intake
Wilson Manifold
2.5" downpipe
3" hiflo cat
Milltek resonated
Could you calcuate the cfm from the info I provided?
Forge FMIC
Airetek intake
Wilson Manifold
2.5" downpipe
3" hiflo cat
Milltek resonated
226.42 g/s @ 6160 RPM, manifold pressure 2250, temp reading 39*C (ambient temp of 84*F)
scfm = standard cubic feet per minute
There are as more "scfm" definitions than there are standardizing committees. I'm using the metric conversion of one commonly used in US (atmospheric pressure 1013 mbars, temperature 19°C, weight of cubic foot at this temperature and pressure 34 grams).
(226.42 g/s) / (34 g/cf) * (60 sec/min) = 400 scfm
So flow volume would be 400 cubic feet if air were open in the room. However air is being crushed into manifold by turbo, so we need to correct for temperature and pressure there.
Pressure correction:
(400 cfm) * (1013 mbar / 2250 mbar) = 180 cfm
Now we need to correct for temperature. At 0°C air will have considerable volume so you need to use the proper scale as was done for pressure (1013 mbars is 0 gage pressure), an absolute scale - Kelvin (273 K is 0°C)
(180 cfm) * (273 + 39)K/(273 + 19)K = 192 cfm
So air flow inside of manifold is 192 cubic feet per minute.
Do a block #120 log from idle speed to rev limiter in 4th gear to get torque & hp plot. A stock 225 will get a hp peak of about 197 hp on average at 5900 rpm. If you do this conversion (225/197) you'll probably be in the 280 hp range.
as Bob stated, it's great to have your knowledge and I appreciate the way you share it.
UrS4boy
Audi Original "S" Cars
02-21-2008 04:24 PM
Illusive90S
05-26-2007 09:45 AM
1.8tScreemer
Performance and Tuning
21
09-28-2004 03:52 AM
Ray Calvo
Wheels & Tires Discussion
02-01-1999 08:40 PM
