just bought a dual 3.2 black valence... need help on installation.
I am probably going to sound like an idiot, but I was just wondering if anyone haa diagram to take off the stock(dual) exhaust valence?
I looked at the bottom of the valence and it has four locations where the its tacked. Two of which are phillip screws.. easy enough, and the other two tacks are round plastic tabs. I can unscrew the phillips, but do the other two require a special tool?
anyways, any help is appreciated.
thanks in advance
-=iLuvTTs=-
thanks in advance
-=iLuvTTs=-
YOu will need a torx screwdriver for the outer ones, but make sure you use a really skinny one for the inner (faceless) screws, or they won't pop out. I spent about 15 minutes trying to push them in with a fat torx driver, and it wouldn't work. Finally, I took a little one and started to stab at it angrily and the center pushed through.
TTongpo had the same problem as me -- read there, and also link to Jeff Bipes's excellent instructions.
https://forums.audiworld.com/tt/msgs/1019532.phtml<ul><li><a href="https://forums.audiworld.com/tt/msgs/1019532.phtml">installing 3.2 valence</a></li></ul>
Disappear lika Ghost
9
07-30-2005 04:40 PM
Norcalguy
11-22-2001 01:33 PM
