KeyFob Questions
1. Can I just replace the battery and not loose the programmed settings ? (I only have 1 key)
2. How the heck do I replace the battery ? I got it appart, but then what ? (sorry for the noob-ness of this question) I saw some diagrams of how it's done, but searching around didnt bring me to them.
Thanks in advance !
Thanks in advance !
For the battery replacement look at this address:
But you will have to use a web translator (German to English)
like:
http://www.freetranslation.com/web.htm<ul><li><a href="http://www.ttr-friends.de/ttr-friends-dateien/index_4-dateien/bauplan/schluessel/home.htm">http://www.ttr-friends.de/ttr-friends-dateien/index_4-dateien/bauplan/schluessel/home.htm</a</li></ul>
like:
pry open the two pieces using the little notch, open the back part, where the keys attach. The battery is in that part. You may have to reprogram, just push the lock or unlock button once, on the key fob, then put the key in the door lock and turn to lock or unlock
Liam in Montreal
08-02-2003 02:09 PM
Ghant TMK
01-06-2003 12:25 PM
