KMACs for more front negative camber?
I want to get more negative camber (for autocrossing) on my 225QC, and I see lots of folks here using KMACs to adjust out the massive neg camber (in the rear) when they lower their cars, but I just want to get more front neg camber.
What are my options?
Kmacs only for the rear. You can loosen the 3 nuts at the outer end of the lower A arm and move your carrier outward a little. They are slotted, but you won't get much change from this. Fully adjustable A arms in the works (Jason?) but not available at this time.
I talked to K-Mac representatives for the better part of last year, and they were working on a front camber adjustment for the TT, but decided that it would be too expensive and there just wasn't enough demand.
I have been able to achieve about -2.5 degrees of camber in the front by slotting both the control arm and the ball joint. I pressed out the studs of the ball joint, elongated the holes and replaced the studs with bolts/nuts. If you have a die grinder and some time it is fairly easy to do.
I thought about sending a set of control arms to a race fab shop in Texas, but at ~$325 for the spare set of arms, and then the $1000 for the custom fab work, it just wasn't worth it.
-Gary
-Gary
ECS Tuning-Audi
S4 (B8 Platform) Discussion
06-14-2019 06:44 AM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
06-14-2019 06:44 AM
