KNEEDING SPONSORSHIP TO FINISH THE BEAST
IM IN THE PROCESS OF BUILDING AN ALCOHOL INJECTED PRO FRONT WHEEL DRIVE 1,100 HP AUDI TT ,THE TUBE FRAME IS COMPLETED ALONG WITH THE ONE OF A KIND 3 SPD AIR SHIFTED TRANSMISSION .THE TRANSMISSION WAS MANUFACTURED BY US ,ALONG WITH THE FRAME .THE ENGINE BASE IS THE 1.8 MOTOR ,IT WILL BE TWIN TURBO VEHICLE.THE BEST PART IT WILL MAKE THE POWER FROM THE STOCK ECU WITH A LITTLE PIGGY BACKING.I HAVE 3 0F THE 5 LEADING CHIP AND HEXADICIMAL CODE ENGINEERS IN THE WORLD WORKING WITH US .THE CAR WILL MAKE 7 SEC PASSES,AND SHOULD EXCEED 200MPH IN THE QUARTER MILE.TOO MUCH TO DETAIL IF YOU ARE INTERESTED IN SPONSORING US I CAN ALMOST GUARANTEE 10,000 MONTHLY FROM FULL SPEEDVISION COVERAGE THAT WAS GUARATEED TO MEE .
TOO MUCH MORE INFO TO LIST PLEASE CONTACT IF INTERESTED.
MARK L. GIFFONE
PH#(954)-804-4248
MARK L. GIFFONE
PH#(954)-804-4248
Are you with HSM Racing in FL?
If so, you should give some details about your shop and the folks working there. Talk about Hans Mundt, who he is and what you guys do on a day to day basis. Also talk about what you've done in the sport.
Blasting out a note on the internet will most likely only get you flamed
![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
