Langka and Touch-Up paint Question?
I just got the touch-up paint. It turns out to have both the paint and the clear coat.
Should I use the paint then Langka. Followed by the clear coat and another Langka?
You will likely have to do several iterations of paint/Langka to completely fill the area before...
...you proceed to the clearcoat. Apart from that, you've got the process down. The Langka is VERY effective at removing the excess paint so if you're not careful, you end up removing it all. Let the paint dry for a good 24 hours before you Langka it.
Mix the touch up paint 50-50. apply, then use Langka.
do it only once...both touch up paints are laquer-based, so mixing is okay. not the best solution, as i can't fill all the chips i have on my BB.
