Lateral Acceleration Sensor
Could a failing lateral acceleration sensor cause my rear wheels not to kick in when my front slip? I've been spinning my front tires way more than I should be able to lately, especially when accelerating through a turn. For a while I had my ESP/ABS lights on ocassionally, now they're always on. The code I got was something to the effect of "Implausible signal from lateral acceleration sensor."
Thanks!
Thanks!
it will keep the ESP(traction control) from functioning which will allow you to spin more. Sounds like you need a new lateral acceleration sensor.
I turn the ESP off everytime I get in my car, and this is WAY more spinning than I should be getting. I've spun them all the way through first, but it only happens every once in a while, usually it's fine.
It's kinda hard to troubleshoot issues like this when you already have known issues. Fix the problems you know you have and then if it's still an issue revisit the excessive spinning.
the ESP/ABS lights come on every couple weeks for a few days in a row, then go away. i can defintitely feel the wheel spin. from searching and responses on the forum, it is probably either the longitudinal or lateral acceleration sensor for me... haven't gotten around to dealing with it yet though.
Automotive_Buff
43
04-29-2019 12:32 PM
TTagz
14
07-21-2010 02:59 AM
all the lights come on like a damn christmas tree.. esp, abs and check engine all at the same time!!
swizznuker
01-06-2008 12:38 PM
