Lateral Acceleration Sensor- searched forum and found many with problem but few replys>>>
ESP light comes on once in a while- vagged car and get the same code as others have gotten.
Lateral Acceleation Sensor intermmittent failure codes 57-10 and 27-10.
As mentioned I found others with same codes but no replys as to fix. I assume it's replacement of lateral acceration sensor. Could it be plug/contacts or most probably the sensor itself? Where is the sensor and can it be replaced without much difficulty?
TIA Bob
TIA Bob
the sensor itself is located on the passenger side behind the glove box. you just have to remove the glove box to get to it. after you replace the sensor you have to zero it out with vag-com i believe.
Mine likes to fuss at sharp left turns only. Apparently it's a sensor that does like 3 other things as well and is thus ?artificially very expensive.
Rich
Rich
harness and wiring connectors also replaced. Still had recurrent intermittent ABS warning light on. Finally Audi replaced ABS control module and so far problem resolved.
Kahuna-Big
12-18-2009 06:23 PM
RASTAMN: is IRIE
11-19-2007 08:10 PM
WaggsA6
10-26-2006 08:16 PM
98Blue
07-23-2003 07:39 PM
