Leaking washer fluid!!...Anyone have this problem and what was it?...
Its leaking from in front of the lt front wheel and bad!. I was thinking maybe a cracked jug, broken hose on the headlamp washers or hose came off. Wonderin if I want the dealer pryin in there since maybe the fender has to come off or if I should try and fix it since I am a careful collision guy!
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
meets the car. There is a little clip that keeps it together and it easily comes off. You can check yourself by pulling the wheel off and removing the fender liner.. it lies right at the bottom of the bumper.
from your headlight washer (alien). You might try removing the lower air vents and looking to the rt. side alien to see if you can see the place where it connect to the washer. Otherwise removing the front end would reveal your issue for sure... butis kinda a PITA.
Dommi3
04-24-2002 07:27 PM
bugbbq
12-21-2000 07:18 AM
