left key in ignition for 10-15 minutes and battery died. Time for a new battery>
#11
it first died at the airport after which it was recharged by the dealer, with an "it happens all the time with these cars with lots of memory" explanation. it died a couple of hours later. it was then promptly replaced. no problems since.
01 225c
01 225c
#13
As a Followup note to Jeff Bipes:
When you replace a battery don't you have to re-code the radio?..My 2000 180FWD coupe was purchased by me last July....I have not been able to get the radio code...I know if I need a new battery I'm out of luck at this moment...Dealer wants substantial money...says they must remove the radio etc. You know dealers...anyway...is there a way to recover the radio code using just the VIN or is it a major process...You can E-mail me so as not to take up Forum space ....
TTemptones1
TTemptones1
#14
the VIN.
They do not need to remove the H/U at all.
Do you have the manual at all?
The code should be in the separate book for the Audio System
#15
No, The page where the code goes is empty apparently someone took it out...If I give them the VIN they can get it...you say they don't remove the radio? told me they have to open that , find some number and then go on the computer with the VIN....sound right or like BS? $35.
#18
If you only need a VIN? they say they had to look on the back of the radio and take off the surrounding dash to get in? Car has been off warranty for a while from Audi..I have extended Warr....I'll try some other people locally too...can I get it on my own? Directions are in manual to re-program right?
Thanks
Paul in Philly
Thanks
Paul in Philly
#19
there is NOTHING on the back, top, sides of the H/U that they need to re-code the 'SAFE' mode.
sheesh, these people are fools.
they need to submit the VIN number through Audi, and Audi will give them the 4-digfit code for the H/U
A8Pete
9
07-18-2016 09:00 PM
awdinut
10-23-2015 11:04 AM
