Lets try this again... will this wheel fit without rubbing, and will I need spacers...
#11
others if I have a BBK? I thought offset would act as a spacer, bringing the wheel in and out from the hub, why does this matter if I have a BBK or not? If the ET25 fits perfectly in front, wouldn't an ET40 stick out really far from the fender?
#14
Perhaps this diagram will help:
<img src="http://www.tirerack.com/images/wheels/tech/offset.gif">
The thing to keep in mind is that the hub distance to fender doesn't change.
You would need a 15mm spacer with the ET40 wheel to make the edge of the wheel sit the same distance from the fender as with an ET25 wheel. Having this spacer allows you to clear a big caliper as the spokes of the wheel would be farther away from the hub.
#20
I have ET25 BBS LMs and porsche 993T monobloc calipers and with that offset, i need 15mm spacers to clear the huge calipers and the tire sticks out of the wheel well.
so it looks like I need to find the smallest caliper available (wilwood) and have to replace my BBK. I'm not too happy about that, since I like the Porsche calipers alot.
