Lighter wheels = more horsepower?
August edition of European Car, page 66. These guys dynoed a BMW Z4M with the stock wheels getting 253/215. Slapped on a set of forged aftermarket wheels weighing 4 lbs less each. Re tested it and got 266/225.
8lbs less rotating mass (2 x 4 lbs) got em 13hp and 10 lb/ft.
Huh!? This sound right to you guys?
no...
from the technical write ups I've read, it does make some difference, but not a whole lot. Certainly not 13hp, not unless the OEM wheels were made of lead.
I can't believe the engine would put out more power, but maybe there is less drivetrain loss due to
the decrease in mass. That would have a dyno on the wheels report higher, but to get the engine HP the correction factor should probably change to keep them the same.
Lighter wheels = less loss
It's not that the engine is making more horsepower, but rather losing less energy in moving heavier parts. The whole idea of unsprung weight correlates to better handling, I've done that with my car and the instant I got back behind the wheel I felt teh difference. With the lighter weight wheels and other things such as lightened flywheels, mean less rotating mass and therefore less energy wasted spinning them up. A sort of ad hoc increase in power:weight ratio if you will.
more torque to the ground since you don't loose it with on heavier wheels rotational intertia...
since it takes more torque to rotate heavier wheels from 0.
And since roller dynos measure how fast the heavy drum spins from one speed to another, it doesn't help to have another heavy drum (heavy wheels and tires) spin it first. That is energy lost.
mbox
22
01-31-2005 09:54 AM
ESFO
04-28-2004 09:52 AM
Silent Assassin
02-20-2003 08:36 PM
Rennen
30
10-23-2001 05:57 PM
