LighTTnin... I tried the 49c setting on the on-board diagnostic system...
and it indeed changes in one degree increments when I would expect it to... seems like it must be actual coolant temp. On my 225, it shows 90* or 91* C most of the time... but after driving for a while, then parking at idle the temp went as high as 100*C then came back down. Cluster temp gauge didn't budge off of middle position-- which is consistant with the +- 10*C normal range of fluctuation (in other words, between 80*C and 100*C is "normal".) If 49c is coolant temp, I wonder what 51c "Engine Temp" is a measurement of, if not coolant?
This was just a short test... I'll try it some more under various conditions and let you know what I find out. Sounds to me like your 120*C reading is high... but maybe not.
PracTTical
13
07-10-2008 06:50 AM
twotruckeetwinturbos
08-29-2007 07:51 PM
sweattdogg
12v V6 Discussion
10
09-15-2005 06:56 AM
Jay 225TTR
9
05-15-2001 08:34 AM
