Looking to fix my squeak sway bar bushings...
Front or rear? Aftermarket or stock? Lots of info in the FAQ - see link:
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1389261.phtml">https://forums.audiworld.com/tt/msgs/1389261.phtml</a</li></ul>
Sorry...
I figured you guys just knew psychically what car I had.
180HP Quattro Coupe - Later Model 2001. Bone stock.
I'm figuring they're 20mm since that seems to be the most common... but that's why I'm double checking. I thought you guys may know just based off of the specifications (which I failed to provide at first).
20mm,,,,,>>
Chisel off the plastic bushing (which is usually the source of the squeak) and replace with 20mm Powerflex.
<img src="http://images21.fotki.com/v840/photos/7/7305/1232358/swaybar2-vi.jpg">
As far as Neuspeed goes... do you recommend going 22mm or 25mm?
Not ready for the front now... but in the future. I still need to get chipped and do DP/exhaust.
