Looking at a used TT. What do these codes indicate?
Scanned the instruments:
VAG-COM Version: Release 607.3-D
Control Module Part Number: 8N1 920 930 J
Component and/or Version: KOMBI+WEGFAHRS. M73 D54
Software Coding: 07244
Work Shop Code: WSC 00000
Additional Info: TRUUT28N611048804 AUZ5Z0A5263093
4 Faults Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
01300 - Control Module for Navigation with CD-Rom (J401)
49-00 - No Communications
01304 - Radio
01305 - Databus for Infotainment
37-10 - Faulty - Intermittent
Also scanned the AWD system:
Control Module Part Number: 02D 900 554 B
Component and/or Version: HALDEX LSC ECC 0006
Software Coding:
Work Shop Code:
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
4 Faults Found:
01304 - Radio
Software Coding:
Work Shop Code:
1 Fault Found:
00-00 - -
Terminal 30 is this link. Might be weak or broken like this.
<img src="http://www.loomknitting.com/auditt/images/TTDeath/batteryterms.jpg">
should I still worry about the Haldex controller? If so how much is a stock unit and can I purchse any rebuilt units?
AmoKK
12-06-2008 09:44 AM
Imola Ghost
VAG-COM Discussion
07-12-2003 09:04 AM
