Lug bolt remover question...
<center><img src="http://pictureposter.audiworld.com/5045/250x000-071-591-a.jpg"></center><p>Yesterday I was finally going to put on the snow tires. One of the bolts was apparently tightened with an impact wrench (some moron) so it started to strip when using the OEM 17mm tire tool. Sprayed inside only with WD-40 and went to 17mm socket wrench which started to strip as well. This is not the standard OEM lug bolt, but the thinner one that accepts the lock (pic). Which bolt removal kit is the best to use with a breaker bar? So far I've seen Craftsman and Irwin.
<a href="http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00 952166000"> Damaged nut remover </a>
<img src="http://content.sears.com/data/product_images/009/52166/00952166000-dlv.jpg">
First , take a 17mm socket and a small sledge hammer(I know this sounds bad) and hit the end of the socket to loosen the threads. You need to use a 6 pt socket and then try and break it loose wt a breaker bar. Does not work all the time , but a good portion of it. Other then that , its time to get the drill out(even thats not that bad).
