mne- do you have an after market air filter? JIM
Guest
Posts: n/a
on any of them... chipped or unchipped... zero, nada, zilch, bupkus. A slurpee from 7-11 adds as much HP as ANY of them. Save the money and go for the enhanced filtration of the stock one with confidence knowing you cant do any better. Unless you wanna buy any of those I mentioned slightly used? Dont!... You'd be a fool. Have a Slurpee on me!
Guest
Posts: n/a
The motor has to breath to make power. Hence, "ramming the bore" with air is accomplished by unrestricting air flow as much as possible. Getting air in (turbo) and getting air out (exhaust) is what it's all about. Not so? Look what a K&N does for a n/a engine. If you want BIG HP gains (chipping, exhaust, turbo upgrade) a free flow induction system is an important part of the program. I think you are mistaking the value of a free flow filter because you are not yet at the performance level that it matters with a horsepressure device (turbo) in near stock configuration. If these motors were n/a, everybody would be flocking to free flow filters.
MNE, you're a racer. Why am I telling you this? What race motor did you ever run (n/a, super or turbo) where this concept was not of major import? Now, don't get mad at me for this post. I just disagree. No oneupmenship intended. OK?
Guest
Posts: n/a
In racing you expect to rebuild motors on at least an annual or bi-annual basis, so you compromise some additional contaminants inside a motor in exchange for power. And a lot of cars I've driven on the street show a marked improvement with an aftermarket, more free-flowing air cleaner. I'm a HUGE K&N fan... used em for years on everything from go-carts to motorhomes. I ran right out and got one the day after I picked up the TT. Sounded great... lots of induction sound, but when I G-Tech'd it... no add'l ponies... none whatsoever. So I mail-odered a couple others from various advertisers here and tried them. Again, no increase in power or elapsed times. Which leads me to believe that Audi has done their homework on the induction system/paper element on this car. Now hold a brand new K&N element up to a light source and look at the huge unfiltered gaps/holes in the oiled gauze-like element and ask yourself if you really want an air filter element that allows THAT much, or THAT large a contaminant/grit/debris to pass thru it and into your motor for zero net affect. Yes... free flowing air to a motor is a good thing. But partially filtered air for negligible return is folly. The Audi TT simply does not return any benefit to an aftermarket filter element. I wish it did... I wanted it to, but alas, it does not.
turkey burger
11
04-08-2003 12:13 PM
TT Hunter
02-27-2003 06:57 AM
PDX-Boy[hermit mode]
06-10-2002 12:03 PM
Bpower
Audi 100 / A6 (C4 Platform)
9
04-24-2002 11:08 AM
