Mofo & 4bar installed. Went for a ride & noticed the boost seems to be a little higher w/..
Old 05-01-2005, 02:14 PM
TTapsale's Avatar
Default **** & 4bar installed. Went for a ride & noticed the boost seems to be a little higher w/..
<center><img src="http://pictureposter.audiworld.com/24828/****.jpg"></center><p>the same exact settings as yesterday.Like maybe 2 lbs more.I should probably dial it back a little?
I lost the metal clip in the engine bay but found it on the driveway when I returned. The slight bump must have dislodged it cause it wasn't there before.Still have ten fingers &amp; no extra parts.Butt dyno says yes!All &amp; all a good mod day!
Old 05-01-2005, 02:21 PM
Member
hAUDIni's Avatar
Default I think I had to dial my BM down too but after it adapted I think it was spot on...
some extra tweaking is definitely in order for optimization!
Old 05-01-2005, 04:19 PM
Kareem of Elise's Avatar
Default Dial it back?!? Surely you jest.......
As long as you're not hitting limp, why change it? Mo' powah.
Old 05-01-2005, 04:29 PM
TTapsale's Avatar
Don't call me Shirley!...It was spiking around 22psi &amp; I want to keep my turbo abit longer! ;-)
Old 05-01-2005, 04:35 PM
Default Bah! I've had 3 turbos already and you're still on your first!
Seriously, though....I hear you....Definitely don't want to go through a turbo replacement (take it from me....I've done it twice, but not because of anything I did to the car).
+pressure
04-11-2003 05:37 PM
Anti Rice
11-18-2002 10:47 PM
Quick Reply: Mofo & 4bar installed. Went for a ride & noticed the boost seems to be a little higher w/..
