more suspension help
hey again! 00 tt quattro coupe. finally have struts removed. i'm having a hell of a time getting the strut to seat in the bottom of the mount. any ideas? another 1/4 inch would do it.
thanks,
mike
thanks,
mike
The Bilstein had an allignment tab on the strut that passes into the control arm. That tab prevented the shock strut from lowering into the hole and bottoming out regardless of how much the control arm was spread. I finally did as suggested above. I applied a jack and compressed the shock until it bottomed out and allowed the clamping bolt to go through. Just go slow
and Mr. Kareem of WheaTT's trick worked extremely well:
take a 3/8 ratchet wrench, which fits snugly into the gap on the back side of the strut cup. While prying the cup open, jack the control arm up and it should go in easily. The key is using the 3/8 ratchet to pry the cup open.
RPortela
11-28-2008 04:36 PM
A8CT
08-29-2003 08:01 AM
