Mystery Issue - Oh Experts, Please Assist>>>>
Right parking bulb not functioning. Replaced bulb and that's not the issue. Hazards work so the bulb is receiving current. Not a fuse issue. The tech working on it is at a complete loss.
Any ideas what the issue could be?
TIA!
TIA!
turn signals... My turn signal and parking light are the same bulb. There's an "extra bulb" with nothing attached. I thought the turn signal bulb and parking bulb were separate but on the 2000s perahps they were the same?
I have the same problem. Turn signals work, but no parking light strip. The problem is that the housing where bulb fits into is all bunged up. The plug twists out of the headlight assembly and is small black plastic piece. On the outside of the plug(for lack of a better word)is a metal strip on each side. These strips conduct electricity. When they are not properly in line, nothing will happen. I went through a few bulbs myself and nothing worked. I then switched one plug to the left side and then right, and bingo, that was it. I tried to fix the little metal strips, but that only made things worse.
*inside* of the headlight.
your problem is one of these contacts is bad.
These parking lamp holders are not designed real well.
try a quarter-turn, and then wiggle it to either remove it, or re-seat it.
<img src="http://ttbipes.home.comcast.net/jpgs/parking.jpg">
<img src="http://ttbipes.home.comcast.net/jpgs/rear2.jpg">
