Need advice on Remote Car Starters
I've decided it would be a great antidote to Michigan winters.
What have people had good success with?
How difficult is it to DIY? (skills/tools needed?)
Thanks,
2001 QTR
Thanks,
2001 QTR
Transmod Bypass. A small box you put your plastic key in, to fool the ignition and cluster to think the key is in the ignition.
if you don't have that plastic one, you will need to use another key.
You will also need a device that will work with manual transmissions. You will need to defeat the Normally Closed and Normally Open switches on the clutch pedal, so that you can start the car without the clutch pedal depressed.
You will also need to get at the wiring under the steering wheel, that goes to the ignition switch. These wires are difficult to work with, and will require careful splicing, and very good electrical techniques to splice into.
You are dealing with high-current +!2VDC and you need to be absolutely sure of what you are doing.
However, once it's done, the results are very cool.
Most have a built-in 'turbo timer' Yes, a real one. It will shut off the car, lock it etc. after like a 2-3 min. cool down.
Don't forget, you can use this in the summer too, to keep it cool, when you step into a store for a bit, and don't want to shut off the A/C.
Also, I tried a few times, the start the car with the remote, while in gear, and the parking brake on - fail. It never did start, or over-come the parking brake. but you need to set it HARD.
It took me a full week-end to install this in the TT, and a few hrs in an A4/S4.
Don't ask me which one is best, they all work to varying degrees.
They get more complex to install, if you want the thing to do more. All will connect to the parking lights, all have ways to use the existing door locks, but not all will integrate with the Audi remotes,
You end up carrying yet another remote.
i posted the wiring schematics for our vehicle in the FAQ's.... so check that out.
tools required are wire strippers, screwdrivers, electrical tape, and a meter. pretty basic...
luckily for us, our cars dont require any bypasses
thank god cuz thats another 100$ part.
but check the FAQ for the wiring, and match up your remote starter wires to the wiring in the vehicle.... give yourself up to 6 hours if you havent done one before.
to such work, then yes, it will be a difficult job.
Also, because of the high-current taps on the exiting wire loom, proper and good solder connections are imperative here, not just electrical tape.
You and I perhaps can assess this and say its not difficult, yes, now that I've done the TT, it's not that difficult, but for someone without the experience and knowledge that perhaps we share, it's still a daunting task.
NOTE:
USE THE FOLLOWING WIRE CONTACT COLORS,
LOCATIONS AND, POLARITY INFORMATION
IN CONJUNCTION WITH YOUR ALARM/REMOTESTART
OR KEYLESS ENTRY SYSTEM INSTALLATION MANUAL,
TO COMPLETE YOUR PROJECTS!
Note: We Do Not Supply Individual
Manufacturers Manuals!
2001 AUDI TT ROADSTER
ITEM | WIRE COLOR |POL|WIRE LOCATION
12V|red |+ |ignition harness
STARTER|red/black |+ |ignition harness
SECOND STARTER|blue or red/black |+ |ignition harness
IGNITION|black |+ |ignition harness
SECOND IGNITION|black/red |+ |ignition harness
ACCESSORY|yellow/red |+ |ignition harness
POWER LOCK|purple/gray |- |brown 10 pin plug in DKP
POWER UNLOCK|red/gray |- |brown 10 pin plug in DKP
Yours is a 3 wire negative system, and you can directly attatch
your keyless entry systems (-) negative door lock output wires, to
your vehicle's wires, WITHOUT the use of 30 amp relays,
or a DLR (Door Lock Relay module).
PARKING LIGHTS +|gry/brn & gry/pur |+ |headlight switch
HEADLIGHTS|yellow/green |+ |headlight switch
DOOR TRIGGER|*1 |- |*1
TRUNK/HATCH PIN|white/yellow |- |trunk pin switch
HOOD PIN|brown/red |- |hood pin switch
TRNK/HTCH RELEASE|purple/green |5wi|trunk release switch
(use 1/2 of the following diagram![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
FCTRY ALARM ARM|arms with lock
FCTRY ALRM DISARM|disarms with unlock
TACHOMETER|green/brown |- |ECM housing *2
SPEED SENSE|blue/white |- |radio
BRAKE WIRE|red/black |+ |brake switch
HORN TRIGGER|black/yellow |+ |at horn
WIPERS|pur/grn & grn/yel |+ |wiper motor
LF WINDOW UP/DN|not recommended
RF WINDOW UP/DN|not recommended
RADIO 12V|red/white |+ |radio
RADIO GROUND|brown |- |radio
RADIO SWITCH|black/blue |+ |radio
RADIO ILLUMINATE|gray/blu |+ |radio
LF SPEAKER|blu/wht - brn/wht | |radio
RF SPEAKER|red - brn/red | |radio
LR SPEAKER|brn/wht - blu/wht | |radio
RR SPEAKER|brn/red - red | |radio
Notes:
NOTE: This vehicle has an immobilizer system that needs
to be bypassed during remote start.
Use TRANSMOD BYPASS PYLINK BELOW
OR LOGIN TO YOUR PAYPAL ACCOUNT
AND SEND 25.00 TO INSTALLSUPPORT@AOL.COM
*1 Use brn/yel or grn/yel in a brown 10-pin connector
in the drivers kick for the drivers door trigger
and brn/wht or grn/yel in a brown 10-pin connector
in the passengers kick for the passenger door trigger.
Both wires need to be diode isolated.
*2 In an orange 10 pin plug. The tach wire can also be
found at the instrument cluster, it is green.
DONE!
Need A Transmod Bypass?
Click Here/copy cut n paste:
https://www.paypal.com/xclick/business=installsupport%40aol.com&item_name=Tr ansmod+Bypass+Module&item_number=Transmod+Bypa ss+Module&amount=25.00&no_note=1&curre ncy_code=USD
* Always use a digital voltage meter to verify wires !
If you do not use a computer safe test probe in
todays complex vehicles, you can do serious damage
to the onboard computer system!
FOR TIPS, TRICKS, RELAY APPLICATIONS,
AND MORE, JUST GO TO OUR MAIN PAGES!
( These pages will come in VERY HANDY! )
www.12VOLTSOURCE.com (Home)
www.12VOLTTEK.com (ALARMTEK Credentials)
www.12VOLTPLANET.com (12 VOLT ACCESSORIES)
www.SUPERSTRONGFILM.com (Serious Car Protection)
www.USCARALARMS.com (ALARMTEK's Store-Big Sale Now!)
www.HONDAGUARD.com (ALARMTEK's Honda Car Alarm Sales!)
www.INSTALLHELP.com (find a tech in YOUR area!)
www.RELAYHELP.com (All Automotive Relay Applications)
www.WIRINGCHARTS.com (Get YOUR Data Charts!)
www.ALARMDOMAIN.com (Car Alarm Reviews)
www.MRINSTALL.com (Car Alarm Installation Tutorials)
COME TO THE Q&A FORUM!!
Get more wiring help
method tips, door lock related info
and 1 on 1 installation assistance
at: www.INSTALLSUPPORT.com
Thank You For Using The WIREWERX!
ALARMTEK AUTO SECURITY / WIREWERX.com
has taken reasonable steps to insure the
above information is accurate,
but offers no warranty, either expressed or implied
of the above wiring information.
The WIREWERX Is
An ALARMTEK Company!
Notes:
DONE!
The WIREWERX Is
