Need help from the brass fiitting gurus!! :D
#11
Scott, worst case give me the compression nut. I can have it drilled and tapped the rest of the
way through. You can use that as a "bridge" to connect the gage male to the second fitting from the left, then you will be on to 1/8 NPT fittings to play at your heart's content.
#13
Whodkne...I took a picture, but forgot my adapter for images at work...but...>>
what you need is a 1/4 adapter female/female that fits on the boost gauge to accept a male 1/4 adapter going to a 1/8 barb for the boost gauge hose. I don't think you need to to worry about the compression fitting. I don't think I have it in mine, and it is working just fine.
#14
Yeah, but mine isn't 1/4 :D
Thanks.. I found some stuff at OSH taht might work. The threads on my gauge are 5/16x24 or M8x1.0 so I got some nuts and threaded sleeves that might give me enough crap to convert it to 1/4" NPT.
s4florida
03-31-2005 05:19 PM
which parts exactly do i need to order for a vdo boost gauge from http://www.ttstuff.com/gauges_gaug
beejohn
01-13-2005 09:16 AM
A Foore
07-11-2004 10:51 AM
