need help with a fault code: 01039
Address 17 -------------------------------------------------------
Controller: 8N1 920 930 E
Component: KOMBI+WEGFAHRS. M73 D09
Coding: 03244
Shop #: WSC 02610
1 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Thoughts, ideas?
Coding: 03244
Shop #: WSC 02610
1 Faults Found:
Thoughts, ideas?
you may need to replace your coolant senor...reset the fault to see if it comes up again
the sensor is located next to the intake box - between the engine and the intake box. You can see it, it's green.
Common for the sensor to die.
Old91CivicGuy
11-20-2004 03:38 AM
CrazyINP-12V Ivan
10-29-2001 05:48 AM
