Need some help installing a boost gauge
I'm putting in the AWE vent gauge, and following the installation instructions that came with the gauge, at one step it says
"Remove the cover off the white wiring connector box in the corner of the firewall area under the cowling.
Remove the rubber blanking plug, as shown in Figure 8.
With a razor or x-acto knife, cut an "X" in the middle of the rubber
blanking plug.
Insert an end of the silicone hose included with the boost gauge
kit, and slip half of the hose through the plug."
Is this (pic from my car) the cover they are talking about? It doesn't remove very easily and it's not white. Also, I don't see a "rubber blanking plug."
<img src="http://www.msu.edu/~lytleric/IMG_0808.JPG">
In the next step, it says
"Drop one end of the hose down through the wiring connector box, into the passenger compartment.
Locate this end of the hose in the passenger compartment androute it through the relay panel under the dash as shown in Figure 10."
I also don't see where this connects into the cabin, which is where you are supposed to route the hose.
Any help? This isn't as straight forward as the instructions make it.
blanking plug.
Those instructions are all bogus. You don't have to do any of that. There is a plug and a pass through under the dash just above the Gas pedal....Feed the hose through there. No need to disassemble all that other stuff....
Sorry...You asked the wrong question first...
and found others who have done the same. Dang, I shoulda done my homework first (rather than trusting the instructions that came with this thing)!
Or drill a hole in the center of the plug and run the hose through that? The hole is larger than the hose so there is a gap around it. Just want to make sure that wouldn't be a problem...
into the FPR. Be very careful putting the hoses on. Any twisting motion without plenty of lube will result in this:
<img src="http://pictureposter.audiworld.com/84508/picture_040.jpg">
I was relocating hoses after installing the Samco intake and while trying to get this off, the frigging thing with the reducer in it twisted...almost in half. Apparently this happens alot as the "T" is on back order due to so many failures like this. Just dump it right off the bat! Buy a decent "T" with a reducer if you can find one...I couldn't. I used a regular "T" without the reducer and then fitted a straight connector with a reducer into the hose leading back to the gauge. Works great...no buzzing.
J4SON
03-18-2002 12:29 PM
Tostao
10
11-09-2001 09:49 PM
audiohs
06-15-2001 09:49 AM
