New tech bulletin....didn't know if it had been posted...translation please!
<ul><li><a href="http://tech.vw.com/audipdf/a010005.pdf">http://tech.vw.com/audipdf/a010005.pdf</a</li></ul>
..are doing is a vacum leak down test of that vacum line, if it does not hold vacum a torn divereter valve dyaphram is the probable cause. To make sure they are clamping off the line at the DV valve and if it then holds vacum the DV valve is faulty. The DV is replaced and the ecu is then reset to standard. JIM
