And, now a chipped Forge DV question.
Getting a great deal on chauffing, or even a whistle with the forge upon throttle lift off.
This is normal, I don't think so.
Also, when I looked at Rd Rockets install his little nipple (no wize cracks :-)) was pointing up mine does not, so would it helped if I flipped mine?
One of the Forge valves vents boost to air. #6 is what you want to prevent re-spool boost...
build up lag time. If its got holes under the cap, it is not optimal. That whistle is your boost goig bye-bye either from vented valve, improper install, or faulty O ring seals.
PZelite_GR
06-05-2003 10:58 AM
Norcalguy
11-01-2001 03:45 PM
