Now I'm doing my 90,000 mile PCV system rebuild -- observations---->
#11
JP....
on the referenced previously posted pictures/article there is the 06A-133-789 hose shown with an attached check valve and another hose on the other end....might I assume this is all one part number? (two hard hoses and the check valve).
Is the clip for the elbow that uses the o-ring serviced separately ? Do you have a p/n on that?
#13
It includes (from left to right) the rubber U bend and connector, the hard hose, the check valve and T, the 90^ rubber hose, the long hard line with the U bend all the way up to 06A-133-783BA.
I reused the clip on the elbow, not sure what the part number is. The o-ring part number is listed as N-904-673-01.
Part #s were all correct when I first posted them. Others have used the same part numbers more recently with no problems.
#17
NOT! I am thinking the same thing. Keeping costs down I will be doing the same deal but removing the manifold. I will be (trying) to simplify things. If I am sucessful I will post with pictures.
#19
I'm not sure that that is entirely safe though. I've got a catch can plumbed in in place of the black pancake valve that hangs off of the valve cover and sits between the PCV vent, valve cover vent and intake hose.
VAP
12v V6 Discussion
13
05-30-2009 11:57 PM
Nate (ETKA+Scumbag)
08-22-2006 08:19 PM
Nate (ETKA+Scumbag)
01-16-2006 05:56 PM
Chuck A6 4.2
01-16-2002 04:44 PM
