NTB screwed up my rims while mounting tires. What can I do?
I got my tires mounted and when I got home to clean off all the brakedust and fingerprints I noticed a lot of marks on the rims. There were a bunch of fine scratches from the mounting maching with some black scrapes that came off with some WD-40. Then to my horror, I saw that they must have took out the valve stem with the jaws-of-life. The area around it is all boogered up. Then I was cleaning off the tape residue from the old weights and saw huge (literally), deep gouges from whatever they used to take them off. To top it off, it looks like the guy doing it was practicing to be a NASCAR tire changer. He needs to go back to school though because he missed the lugs a few times and dinged up the face of the rims. I am so pissed off about it and wondering what kind of retribution I can get from them. The rims were pristine before and now are noticably screwed up. Any help would be appreciated.
Thanks,
Greg
Thanks,
Greg
They screwed up a Porsche wheel of mine a couple years ago after SPECIFICALLY telling me they could do it. I threw a small fit when I came back for the wheel (my young son was with me) and demanded a new wheel- I think the guy was scared- they got me a new wheel from Wheel Enhancement ( a new take off) after I gave the name of the place. They first said they would have it fixed, and I said that wasn't acceptable. Good luck.
Several small scratches on the face, and the valve stem rim area was <i>totally</i> chewed up.
This is because the "correct" way to pull a valve stem is to remove the tire and snip it off from the inside of the wheel. But that takes time.
99.9% of the time they use a tool that works like a bottle opener - it has a hook that hooks over the rim and they pry the valve stem off; instantly deflating the tire, saving them two steps of work. Of course, since you're prying on aluminum, you can guess what that does to your rim...
I never did get a satisfactory response. They wanted to send the wheels out to be refinished, but that takes 3-4 days each and unless you enjoy driving on your compact spare for a <i>month</i>, that's not an acceptable solution.
Worse yet, the wheel that did come back looked like the shop just sprayed it with Krylon Clear Coat.
I decided to live with it, as odds are road crud will scar my wheels up anyway, but by all means at least <i>try</i> to get NTB (or Tires Plus, or whoever) to pay for new wheels; I doubt you'll succeed, though...
As a side note, since my wheels had already been damaged once, when I needed to have another set of tires mounted, I went with a tire shop recommended by my dealer as they use them for all their work.
That shop not only put in <i>more</i> scratches, they also lost <i>all</i> of the grey plastic lug bolt covers (yes, all 20...)
t0mt0m
02-22-2004 10:57 AM
stevo_devo
SoCal Discussion
10-02-2003 10:40 PM
GDavis
25
01-02-2002 08:22 PM
GDavis
01-02-2002 10:10 AM
GDavis
Wheels & Tires Discussion
01-02-2002 09:50 AM
