Octane Boost - Since Calif. is lowering Octane levels from 92 to 91, here's some off the shelf
products that might help (not sure).
I'm sure these products are also available at your nearest automotive store or Target, Walmart.<ul><li><a href="http://search.shopping.yahoo.com/search/all?P=all&is=1&p=octane+boost&cl=dmiyg">http://search.shopping.yahoo.com/search/all?P=all&is=1&p=octane+boost&cl=dmiyg</a</li></ul>
AudiWorld Expert
The octane boost products increase octane in the range of tenths...that is ...you put in 91 octane in your car...you add a bottle of 107+...it increases your overall octane to 91.4...91.5 or so. Therefore, I would not waste my money on this.
Add 1 to 2 gallons into the tank, and you would get about 96-98octane.
If you look at the Octane boost, it will also have toluene in it, except, your buying 7 dollars a quart instead of 7 dollars a gallon.
Ended up adjusting ignition. Going on a trip was a joke. When do you fill up and what percentage of which with tank not empty? Sure not driving TT with a gas can on the roof or in the trunk.
AizazBlack//S4
13
11-18-2001 06:19 PM
What octane should i use? here in mexico its only available 92 octane, should i use octane boost, if
TTEBERTT
9
10-15-2001 06:00 PM
