Oil question
AUDI vehicles with LongLife service
Engine oils for vehicles with LongLife service VOLKSWAGEN 503 00 for petrol engines
VOLKSWAGEN 506 00 diesel engines without pumpe-Duese
VOLKSWAGEN 506 01 diesel engines with pumpe-Duese (only a2 TDI)
VOLKSWAGEN 503 01 for the following turbo engines: TT (165 KW), S3 and RS4
Engine oils for vehicles without LongLife service
VOLKSWAGEN 502 00 for petrol engines
VOLKSWAGEN 505 00 for diesel engines without pumpe-Duese
VOLKSWAGEN 505 01 for diesel engines with pumpe-Duese
"Vehicles, which are not equipped with the LongLife technology, may not be filled for technical reasons with LongLife engine oil (Volkswagen standards 503 00/506 00 and 506 01)! "
I heard the "technical reason" was that the oil was too low in viscosity at regular starting temperatures, however the manual states you can use regular 0W-30 oil so that can't be the case. Mobil 1 0W-40 meets specs for VW 502 00, 505 00 & 503 01. The statement not to use Longlife oils in standard engines does not specifically mention 503 01. Anyone now the reason for the restriction and why 503 01 would be exempt?
bac2h
Q5/SQ5 MKI (8R) Discussion
10
07-09-2012 10:28 AM
JoeO
Performance and Tuning
09-13-2007 05:14 AM
