oil sensor
The warning light came on couple times last week. It came on while I was driving but then went off couple minutes later. Is there anything I need to worry about? How much will that be if I need to replace it?
The oil level sensor and its wiring is relatively low in the oil pan and might have been disturbed and/or failing. However, your symptoms are also identical to the oil pump failing. Assuming your oil is properly filled, you don't want to be ruining your engine driving on low oil pressure.
hardipk5
17
11-24-2015 03:42 AM
abpuma
09-17-2015 11:39 AM
