OK, another spacer n00b question concerning bolt length >>
I want to space out my stock 17" six spokes, 10mm front and 20mm rear. Stock wheel bolt is ball seat, 27mm length. ECS has 47mm bolts which are perfect for the rear but for the front the choices are 35mm (2mm short of perfect) and 40mm (3mm long). Which do I go with? I'm thinking 35mm but want to be sure before I order.
Well I just pulled one out and measured it >>
Looked like closer to 27 than 28 but hard to tell for sure.
I was just concerned that having too long would interfere with something on the inside of the hub.
I'll go with 40. Thanks.
Steve's right - 28mm. You should get the longer ones and cut them >
watch the rears though - depends on the STYLE of spacer - thicker ones bolt directly to the hub, and with a 20mm spacer you may end up with a 23mm lug nut. Call ECS and discuss!!
I was going with the H&R Trak+ DR series spacer >>
That requires a bolt through both the wheel and spacer to hold it to the hub. Looks as if 25mm and larger bolt to hub first then wheel bolts to spacer
I think you have a screw loose :->
Besides if I'd have said wheel <i>screw</i> no one would have known what I was talking about. Seriously, you may be correct by the dictionary definition but the common usage for this application is "bolt". It's a minor technicality as far as I'm concerned. Maybe you can get ECS Tuning to correct their page.<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&engine=180HP&mo del=TT&submodel=FWD&category=Suspension&am p;subcategory=Wheel%20Bolts">Wheel Bolts for TT</a></li></ul>
needforsleep
Wheels & Tires Discussion
13
11-18-2003 11:06 AM
