Ok guys, here's the real deal about the DSG and Launch Control... (long)
#22
dealer service sucks. When you have a problem it's one of:
1) Problem not found/can't be replicated.
2) Problem caused by aftermarket fuzzy dice hanging from mirror - non warranty repair - $$$.
3) Parts are randomly replaced hoping to fix it, each time requiring another trip/alternate vehicle arrangements.
or finally,
4)Problem is fixed, but they break something else in the process.
Repeat.
(edit: I forgot the ever popular 3a) "They all do that.")
or finally,
Repeat.
#23
a new steering wheel, wiring harness, auto stick shift with all required wiring, and.. a complete euro-spec DSG 'box - for your R32 conversion!! Oh, and the super-expensive alu paddles from the *real* R32 DSG :-P
Here's a picture of the Euro-spec paddle circuitry showing the two resistors here:
<img src="http://hitechgti.50megs.com/audi/paddles/paddles03.jpg">
BTW I forgot to ask you, did you erase the '/OFF' text from your right alu paddle for the TT? if not, would you consider a swap? ;-)
#25
such changes of the TCM :-(o)...for a special one...! It seems to be like a scandal.... US market has clearly been spoiled, with a minored 3.2 TT compared to the original one, to limit performances , even if the garanty is longer than ours...
About Manual Over-ride: and the Euro-spec TCM, with the over-ride which does NOT timeout after 15 seconds, if you hold the right paddle for a couple of seconds!!!.... I've to check that ( each time , i use manual mode is for changing gear quickly under the limit of 15 seconds... or /oblige me to move paddle up-down quickly/move the stick left-right.
If I know this now, it may be interesting to drive different.
Thanks for that , Marc.... ;-))
#27
BTW Philippe thanks again for being such a great source for the hundreds of paddles you ordered for enthusiasts around the world, I'm sure everyone who got in on it while the price was still "low" in France really appreciates your efforts!!
#30
By the way Philippe here's the VAG scan from my new TCM, it might even have different Controller & Component numbers than yours:
Address 02: Auto Trans
Controller: 02E 300 046 E
Component: GSG DSG 0629
Coding: 0000020
Shop #: WSC 04940
No fault code found.
You know what, maybe it's a TCM from the R32-spec DSG! now that I think about it, they have this feature with the +2 second hold to turn of manual over-ride.. I was speaking to a French R32 DSG owner and it seems there were a few differences, <a href="http://forums.vwvortex.com/zerothread?id=1668639">see this link from VW Vortex</a> for more info:
1. le OFF sur la palette + de droite sert lorsque tu es en mode D ou S.
En fait, par exemple, lorsque tu es en mode D, tout se fait tout seul.
Mais tu peux intervenir directement sur les palettes au volant pour prendre le contrôle des vitesses sans pour autant passer ta boîte en mode séquentielle.
A ce moment lÃ*, tu as les vitesses qui s'affichent comme si tu étais en mode séquentielle.
Mais étant donné que tu es en D, si tu freines et que tu ne rétrogrades pas avec la palette de gauche, la boîte va rétrogader d'elle même et le mode D revient de lui même (le mode "séquentielle temporaire" que tu avais lancé en actionant une palette se quitte).
En fait, le OFF sert Ã* quitter ce mode "séquentielle temporaire" quand il est lancé.
Exemple : tu veux doubler une voiture alors que tu es en "D".
Tu veux prendre les commandes de la boite sans toucher au levier.
Ainsi, tu rétrogrades avec la palette de gauche : tu es donc en mode "séquentielle temporaire".
Une fois ton doublement terminé, tu désactives ce mode temporaire en "cliquant long" sur la palette de droite, ce qui correspond au OFF.
Coding: 0000020
Shop #: WSC 04940
