ok guys - I NEVER thought I'd ask this, but I need to upgrade my speakers >
#15
local shop put in a boston acoustics amp and speakers and i kept the headunit. used a gt-40 amp and pro series in front sl series in back in my 06 coupe. i did not have the bose upgrade on my soundsystem. sighting the amp was a little difficult but it ended up in a space within the wall of the hatch. the main problem they had with the speakers is that the oem grill openings are very small for the speaker size and i was bottoming out my speakers against the door panels with crazy vibration. a little more dynamat fixed that. i would consider having new speakers grills put in if sound quality is paramount over stock appearance.
#18
Just had to remove the OE speakers from the brackets and drill two new holes in the bracket for the new speakers.
The front Boston Acoustics took a little customizing since they are component and the crossover had to be installed. There is a write-up on my website.
The new rear Boston Acoustics are 5 1/4" components and were definitely not "drop-ins". I'll be updating the speaker/amp write-up eventually.
Grant
Grant
#20
<center><img src="http://pictureposter.audiworld.com/76148/img_2549.jpg"></center><p>
6.5" Polk Separates Front
6.5" Polk Rear
Kicker 350.4 Amp for power
2 Kicker 12 CompVRs
Powered by MTX 7801 Monoblock Amp
JVC Arsenal Series Headunit with SD Card
False floor in back for amps, Fiberglass sub enclosure
6.5" Polk Rear
2 Kicker 12 CompVRs
