ok.. having some real issuies with boost machine >> (kinda long)
Member
so i finally got the boost gauge in, so i was able to tune the boost machine.. i did exaclty as the 'hows and whys' told me to from the autospeed article. now my boost machine is hooked up like so:
pressure relief line hooked into the line pulled off the n75, and the line from the pressure regulator is hooked into the n75.
i had the pressure regulator screwed clockwise completely, and the pressure relief valve screwed anticlockwise completely. which should be stock boost... which is coming up around 9psi.
now no matter what i adjust on the boost machine, my psi just keeps dropping, and the wastegate seems as if it kicks in even sooner
so can anyone help me without this issue?
...on a side note, putting the lower dash back in i think i pinched a line on my headlight switch putting the boost gauge in. because now my foglights are on even though its not pulled... but its no biggie. ill fix that tomorrow.
Reset the machine...start with 4 turns on the boost **** (right) and then move up in 1/4 turn increments every 20-25 miles or so.
You shouldn't have to go any higher than 5.5 turns.
Follow my instructions, Not the autospeed ones...
The valves were set to "off" when you received them
Charged pressure goes to BM "In" line (the one with the plastic barb.) You should have removed this from the BOTTOM of the N75 180 degress (opposite) from the solenoid plug. "Controlled" pressure line shown off the SIDE of the N75 is the one that goes to the Wastegate and is NOT TOUCHED.
<img src="http://images106.fotki.com/v506/photos/7/7305/1552479/N75toBMconnectionsvi-vi.jpg">
from Steve's setup....I think they were using the inline 5 cylinder on that article.....don't know how that's setup.....
Member
<img src="http://pictureposter.audiworld.com/139246/0525080003.jpg">
<img src="http://pictureposter.audiworld.com/139246/0527080001.jpg">
<img src="http://pictureposter.audiworld.com/139246/0527080002.jpg">
<img src="http://pictureposter.audiworld.com/139246/0527080003.jpg">
the hose by the left **** is hooked into the hose removed from the n75. the hose from the right **** is going into the n75
Did you remove the N75 electrical plug? Plug it back in?
Did you do any boosts checks after putting in the gauge and before the BM? 9 PSI would indicate a problem elsewhere. Measuring in 3rd gear right?
Reminder on the Valve turning...
<img src="http://images33.fotki.com/v1187/photos/7/7305/1552479/boost_machine-vi.jpg"><ul><li><a href="http://www.modshack.info/bminstall.htm">You should be using these instructions..</a></li></ul>
I just remember that the setup is different with an N75 for a 180 and one from a 225. I thought maybe the autospeed article setup was similar to a 180 since they were using an older inline 5 or something......
Member
i installed the gauge after the BM was already in (because the BM was untouched which would mean its at stock) and yes i was using 3rd gear. it may have hit 10 lbs.
it still spools normally and everything, sounds normal, runs normal, im not getting any warning lights or any lights on the dash like that.
so im completely lost at what to do
