P0420/P0422...
P0420/P0422...
"Catalyst System Efficeincy Below Threshhold" Anybody with 42DD DP got this code before? Is the car getting the fault codes because of the "high flow cat" OR do you think my 2-months old cat is dying already?
Thanks for your help...
You knew this was going to happen....>
From reading here I hope! CAT is fine, the readings expected just aren't being met by the rear 02 because of the increased efficiency.. Did you install the 02 angle adapter? This usually cures the issues for most..
Here's a previous thread....
Price should be around $40<ul><li><a href="https://forums.audiworld.com/tt/msgs/1792963.phtml">https://forums.audiworld.com/tt/msgs/1792963.phtml</a</li></ul>
