Paging "msauve" Are you around?
[The new headlight switch has an additional control, which allows manual control of headlamp aim (for non-HID applications with manual headlamp adjustment). A future project is to wire this into the auto-leveling circuit to allow a small bit of "fine-tuning."]
Did you ever pursue this project?
Thanks!!!
Thanks!!!
did some checking, and the headlight level controller only makes changes when the car is first started, or if the passenger door has been opened more than 30 seconds (or something like that), so tying it into the sensors is out. That leaves having it modify the signal to the headlights, or the signal from the position sensor in the headlights.
The controller in a coupe is in the rear seat area, as I recall.
I just never got around to running wires to play around with it.
I have the wiring diagrams and it looks straight forward (kinda) but I thought I'd ask before I went cutting into wires. I have a roadster, so I'm not quite sure where they put the control box.
spiralsmurf
Audi Original "S" Cars
04-27-2006 12:57 PM
TighTT
03-08-2005 10:01 AM
