Passenger Window stuck up; after dead battery
2002 TT Roadster Quatro, parked for a few weeks under its cover. The battery died at some point. At first the trunk and fuel door wouldn't open. That's now resolved itself. But the passenger window won't open. It's "stuck" in the up position. It doesn't open that little bit when the door is opened, and it doesn't open that little bit more when the top is lowered or raised. I can hear a click when the window switch is pushed either up or down, on either the passenger or driver door. But it doesn't move.
I suspect it's still related to the security system and the battery failure. But how to reset it?
I did just replace the battery. So the voltage is good. And, everything else is working.
Ideas? Suggestions? Thanks!
In the end, we just had to wait, and eventually, after about ten days, the module and the window decided they'd work together again. And so it goes...
