possible to change the whole emergency flasher switch by myself, how much?
how hard to change the whole emergency flasher switch, and how much? the signal light is random to turn, I am afraid dealer will void my warranty, so I dun want to go back dealer to fix it,
You cannot pry these buttons out from the front. They are in their own special plastic holder. You will see this when you get this out.
I hope you have small hands, and band-aids.
You are gonna need 'em.
You will need to completely remove the radio, and then stuff the cables back down into the space in back where the radio was, to get at the cover mentioned here.
If you don't feel at all comfortable doing this, I'd leave it for the dealer. It's a PITA.
<img src="http://jbipes.home.comcast.net/gifs/switches.gif">
Pull cover plate - 1 - downward using hole - 2 - , and remove cover plate from radio opening.
- Unplug electrical connectors for switches in instrument panel.
- Release 6 grey retainer pins for switches by pulling lever - 3 - downward.
- Then remove switches by pushing them out toward front of vehicle (arrow) and taking them out via radio opening below.
Installing
- Installation is carried out in the reverse sequence.
Installing
Bob W.
10
11-02-2004 03:37 PM
jgriff
05-06-2002 02:47 PM
